OK have a 64 Dart with a 416, had a custom radiator made, long story short, the guy is suppose to be a Mopar guy and his radiator sucked! Fit issues, is only good down the track, should be larger even though it is an aluminum 2 core super duty aka per him.
I sent him my factory 273 core that was a modded 3 core and he still messed it up 4 times. Lower hose to close to center hit crank pully, then the entire core is too tall and hood wont close either! list goes on and on..
So anyway I need a radiator and if possible a larger radiator to cool this beast.
Anyone have a contact, part number what did you do etc?
the core support opening is small and 64-63 used the same offset /6 radiator and mounts.
So I am open as what to do without a major hack job on the front end. thanks!
Has anyone made a later say 68-70 core fit? i think they are 26" wide?
thanks! all
thanks! all
