[WANTED] Radiator Overflow & Washer Fluid Tank
KOZ45
Indiana
Rating - 0%
0   0   0
Looking for a radiator overflow tank and a washer fluid tank for my 1970 Duster
Condition does not matter, as long as they do not leak and have caps
Thanks!
Thanks. I just saw my radiator has fitting under the cap for a line so I figured it was worth a try
Those old ones dumped overflow out on the ground. I am using a Dorman brand aftermarket replacement hyundai tiburon overflow bottle. Here it is mocked up on a 67 barracuda. I used 1" square tube as a riser with the tiburon mounting bracket. I drilled and moved over the one horn a bit.
Washer tanks were manual foot pump type with 2 speed wiper or electric with 3 speed or V speed wiper. Which do you need
Still his is a 70. 73 up they moved the horns to under the battery tray to make room for a charcoal can and an overflow tank. Not sure he wants to reinvent the wheel so to speak for a puke bottle.
