Radiators
Red Beard
Active Member
Cincinnati, Ohio
I was wondering about radiators. How much difference is there between the /6 and 360 radiators. What size would be appropiate for a 360 ?
Thanks
James
the slant 6 radiator is really small (18"?)0. a V8 car came with a 22" or bigger.
that is a big diferense! i´m using a radiator from a ford scorpio with automatictransmission and it works great with mrgasket fan.. it just barelyfits in betwen the framrails!
You can modify a 26" radaitor to fit between the frame rails. Wider radaitor cools better. Although you can run a 22 inch radaitor on a 360 with no problems ussually.
After thinking about it isn't a /6 like a 20", v8 was like a 23 or 24?
Ok, a 22" will do it, a 26" does it better, but needs modified, alright you've made up my mind. I'm going with a 24" :roll:
Thanks Guys
