radio and glove box trim ?
pagilman
farmingtonPa SilverSpr FL
Hi, I found a dart in a salvage yard with the full wood grain trim around the radio and also the glove box is wood grain. I would like to put it on my duster. Will this be a big job to remove and to install on my duster. Have you guys done this and do you have any pointers on this? thanks walt :scratch:
I found the same thing a week ago and grabbed it becaouse it was almost free. The problem with putting it on my Demon was the Demon dash has no holes in it for the pins on the trim to go through. My guess is that you would be in the same boat.
Jack
you are right jack. the holes will need to be there. glovebox you can replace pretty easy, door and all if it is the same color. if it isn't then take the woodgrain off and paint to match then reinstall the woodgrain and install in dash. the other sections need holes. still could do it but you will neeed to drill them to make it work. it won't be easy though.....
