osxdos
72' Duster / 360
What can I tie into for CD player .... I've got a 10amp inline fuse for it, the radio spot on fuse box is in use for my Pro Tachometer. On the same bus is factory ground, then I'm using the third plug for my Sunpro volts reader. I have a spot open on second bus, which is also 20 amp fuse.
