Raised with Mopar blood.
JHillWRX
Active Member
East Cincinnati
Very long story short, I recently aquired the 1974 Dart Sport my father and I had restored before he passed away in 2002.
It had been parked and sat for the last 15 years in my mothers garage, she didn't want it to move.
I have gone through the normal routine of a car that has been sitting; in order
Drained and replaced gas / oil / water,
New plugs,
New optima battery,
New starter.
Finally got the engine cranking and turning over strong, but no spark.
Tested the coil, got good ohm readings. I don't think the coil is getting power.
Distributor was brand new and ran before parked, looks clean, plug wires new basically as well.
Need to check continuity from leads and am looking for information on the ignition system, like a troubleshooting guide/wiring diagram.
I am pulling on stuff my dad taught me 20 years ago in highschool... and what i can on google.
Really excited about finding an active forum dedicated to A-bodies.
I have been on Subaru discussion boards for a long time, same screen name. Drive a Subaru WRX, have 4 Subarus in my driveway... compared to those working on the Dart is a dream, even though the starter was trapped behind the long tube headers and had to drop the exaust manifold and drain the antifreeze, was still easier than just a spark plug change on the WRX.
Appreciate all the information available here!
Ive been searching for info before i start a new thread, having trouble finding a troubleshooting schematic section...
Check for power at the ballast resister.(both sides)
Welcome aboard ! if you are looking for info and good folks you have found the site you was looking for :thumbsup:
Alright....
Thanks for the warm welcome!
Since my last post, I have replaced the ballast resistor, the ignition coil, and the distributor.
Its running a 5 pin box that was brand new...
I traced the wires and they are all connected correctly... need to trace down a bad ground or a direct short to ground or something is my guess...
Welcome !!!
Sweet ride !!
Very sorry for the loss of your father .
I hope the dart sport will bring you close to the memories of your Dad , and become a source of healing for you and your family !!
God Bless
Jim
