Ralley wheel size?
dusterdemon
southern Indiana
Was there only one width ralley rim for the A Body cars (71 Demon small bolt pattern)? What width was that? Thanks Warren
# 51 1970-71 Rallye wheel Abody 5.5 wide x14"
1972 same size
1973 Abody went to large bolt pattern for 90% of the cars.
Mrmopartech, I have a 71 Demon and was wondering what was the correct size, or if there was more than one size. Thanks for the help.
Hello Duster- You can get a larger size rim for the small bolt pattern if you want through Summit, Wheel Vintiques, or some of the other companys that sell the vintage rallye wheels. You may be thinking of the large bolt pattern rallye wheels that were found on E and B body cars. Some of those got as large as 15 X 7. As Caveman said for your car a 5.5 x 14 with a 4" b/c is correct with probably an E70-14 tire.
