rally vs standard dash frame ?
draginmopars
Shady Hills, Florida
can the rallly dash be bolted/modded to a standard dash frame
the rally dash frame
we have is rusted at the bottom
I can cut out the rust and splice in a section from another standard frame
we have this one that is out of a 70 also- headlight switch seems to be in the same position
we are taking it out anyway to put a fiberglass one in
That why, I was thinking if I could use the standard frame and convert it to a rally
Thoughts??
Thanks> always trying to learn
the radios are in different locations .....the whole radio plug on the frame would have to be cut out and moved over ...cant remember now but IIRC its almost an inch off would makes a huge difference and can be a show stopper if its not in the right location.
This project can be done but its going to be a ton of work.....I tried it before.
also depends on what year of rally dash your planning on using....thumbwheel or knobs?
