Rallye Wheel Center Cap Fastener Size
IIRC they are pretty short. 3/4? Should be easy enough to tell by looking at the depth of the hole. You don't want them to bottom out, is all.
1/4 20 x 5/8 long.
These have a 5/16" head
Make sure you clean and lube the threads in the center caps. They're pretty soft, and easily corrode. I use a product called Balistol, usually used on firearms. It leaves no residue behind, and it will help you easily remove them in the future, without degrading the pot metal screws in the center caps.
