Garys72Duster
May work, if you bolt it to the motor BEFORE you weld it back up. You know, I have 2 low deck Weiand Hi Rams. Would be willing to trade 1 for a 440 size. I'm running the Stage VI HEADS, so am using the spacer plates. Would rather use the 440 size, without the plates. These heads require spacer plates when using a low deck intake. Or a hi deck intake without plates. I would trade you, but then shipping costs......pretty high.hi all,
i'm struggling to find a tunnel ram for my 383 for reasonable money here in the uk. i've got a lead on one for a 440 so if i get it the plan is to narrow the base (cut a section out of the middle, lengthways), weld it back together then adapt the top back on. the ally welding isn't an issue, but any other problems i may not have thought of?
cheers, neil.
