mopowers
For those of you with stock length A body rearends and B-body brake offsets- where did you buy you rear hard lines??? I called http://finelinesinc.com/. They are an awesome company, but the hardlines listed on their site are for stock application and the gentlemen I spoke to said the lines they stock wouldn't fit based on the 10" B-body backing plates because the wheel cylinder is in a slightly different place. Anyone else run into this problem??? Is the offset on a A-body backing plate that much different from a B-body backing plate??? I'd make my own lines, but I'm not too confident in my flaring ability.
Thanks guys!!!
Thanks guys!!!
