moparmat2000
Hi Y'all,
I am working on building a dolley for removal and installation of rear axles that can be used under A,B,E,C cars and trucks & vans, or essentially any leafspring car or truck whose axle tube fits the diameter dimensions.
I used to do the barbell balancing act with a floor jack when i was young, but feel i have gotten older, and smarter, plus now i have welding and fab skillz.
I am posting what i have done to build it so far against my better judgement since a lot of times life gets in the way of garage time as evidenced by my cuda being not finished after almost 10 years.
The design of this is going to be so that it will accept 2&1/2" axle tubes up to 3&1/2" tubes for the ford 8.8, and Dana 60.
The design will also allow axles with forward and rear loading gearsets to be built up on the dolley, additionally the leaf springs can be installed while on the dolley, as well as axles and brakes. Then everything can be slid under the car and bolted up as a unit using the assist of your floor jack by attaching at the front spring eyes first, then using the floor jack under the pumpkin and jacking it up and off the dolley to attach the rear shackles.
Now theres T shaped dolleys for installing the complete driveline from the trans forward to , and including the K frame and front suspension that i plan on copying. However i havent seen anything to load a rear axle and springs as an assembly, so i am designing and building one.
I had 4 5" swivel lock castors, and some 1/8" steel plate. So that saved me some money, however i had to purchase rollers, hardware, and an 8' length of 2" thin wall square tubing. The width of this is so that an A body mopar with a narrowed rear for a minitub setup can fit on this.
So follow along and i will start the picture show.
Matt
Matt
