Rear Axle Shafts Won't Seat After Bearing Replacement
BTW, if those seals have a tensioning spring, make sure they are in the seal before you set your axles.....
I usually pack the area with grease where the spring sits, less chance of the spring dislodging when driving the seal home.
When I was 16, I didn't grease the driver side bearing after replacing the seal and screwed up the housing end. I made a dumb mistake. Thought the bearing would get lubed by the diff oil even though I was fully aware of the seal placement. My 8 3/4 I'm building has green bearings. So sealed.
