Rear Brake Line with Super Stock Springs
74DartSwinger360
The Brat Pack
Valrico, Florida
Hey Guys,
What are you using for rear rubber brake lines when installing ss springs cause the rubber line I have with stock springs is at almost mx stretch when suspension is at full deflection.
Thanks for any input
If you can find one get one from a "C" body. I look for a 1970 Imperial as it is the longest I've found. OR you can re-locate the frame bracket lower/longer .
If I remember correctly, I asked the part store for a rear brake line for an '86 Dodge 4X4 Truck and it was more than long enough.
