Rear coil over shock spring rate
rick4106
louisiana
Just installed Dana 60 ,ladder bars and coil overs. Has 150 lbs springs. This is on a mini tubbed abody 3200 lbs. What spring rate ?
You're one up on me; I don't even remember what rate mine are. Good luck.
'71 Duster 2860# (3100 with driver) ladder bars, Think mine were 120's, remember thinking that seemed pretty light, but they worked good. Best bet would be to call or email some of the chassis places and see what they suggest.
We use 110 lbs springs....but we are a couple hundred lbs lighter.....I dont know how much weight is on the rear either...
Since this is in the racing forum, I'm guessing this is a race only car? As said, you really should get the rear sprung weight of the car to choose a set of springs.
