Rear diff ID
63SplitWindow
Montgomery County PA
Looking to identify the rear diff that came in my race car. I want to replace the brake shoes and wheel cylinders. It is a squeezed 8.75 with a 742 center section. The drums are 11" and the shoes appear to be 2.5" wide.
Any ideas what Mopar came with those specs?
B-bodies, E-bodies, some C-bodies, F/M/J/R bodies all had 11x2.5" drums as options. Also some vans and trucks. There are also 11x2" and 11x3" versions running around, you have to match the backing plates and drums based on the size (ie, if you have 11x2.5" backing plates you can not use 11x2" drums)
CHRYSLER 300 (1966 - 1971)
CHRYSLER CORDOBA (1975 - 1982)
CHRYSLER FIFTH AVENUE (1983 - 1989)
CHRYSLER IMPERIAL 1974
CHRYSLER LEBARON 1981
CHRYSLER NEW YORKER (1966 - 1982)
CHRYSLER NEWPORT (1966 - 1981)
CHRYSLER TOWN & COUNTRY (1966 - 1995)
DODGE ASPEN (1976 - 1980)
DODGE B100 (1971 - 1980)
DODGE B150 (1981 - 1984)
DODGE B200 (1971 - 1980)
DODGE B250 (1981 - 1984)
DODGE CARAVAN (1991 - 1993)
DODGE CHALLENGER (1970 - 1972)
DODGE CHARGER (1970 - 1978)
DODGE CORONET (1970 - 1976)
DODGE D100 PICKUP (1972 - 1979)
DODGE D150 PICKUP (1977 - 1984)
DODGE DIPLOMAT (1981 - 1989)
DODGE GRAND CARAVAN (1991 - 1995)
DODGE MAGNUM (1978 - 1979)
DODGE MIRADA (1980 - 1983)
DODGE MONACO (1969 - 1978)
DODGE POLARA (1969 - 1973)
DODGE RAMCHARGER (1974 - 1984)
DODGE ROYAL MONACO (1975 - 1977)
DODGE ST. REGIS (1979 - 1981)
DODGE W100 PICKUP (1974 - 1977)
DODGE W150 PICKUP (1977 - 1983)
FARGO B100 VAN 1972
FARGO B200 VAN (1971 - 1972)
FARGO D100 PICKUP 1972
FARGO D110 PICKUP 1972
PLYMOUTH BARRACUDA (1970 - 1974)
PLYMOUTH BARRACUDA GRAN COUPE (1970 - 1971)
PLYMOUTH BELVEDERE 1970
PLYMOUTH BELVEDERE SATELLITE (1970 - 1971)
PLYMOUTH CARAVELLE (1978 - 1988)
PLYMOUTH CARAVELLE SALON (1980 - 1988)
PLYMOUTH CARAVELLE SE 1985
PLYMOUTH CUDA (1970 - 1974)
PLYMOUTH FURY (1975 - 1978)
PLYMOUTH FURY CUSTOM (1971 - 1975)
PLYMOUTH FURY CUSTOM SUBURBAN (1970 - 1975)
PLYMOUTH FURY GRAN COUPE 1972
Hmmmm.......could be....I will look up some C body info
FARGO B100 VAN 1972
thanks 72
FARGO B100 VAN 1972
Thanks 72. Any idea which of these cars came with a 742 chunk? I realize it could have been changed out but maybe not.
Nice list! I knew I'd seen them on C body's. So many parts have been changed around over they years. Makes my mind melt.
Heck, my 66 Sat was Frankensteined lol, 1970 K member FMJ body brakes van transmission truck rear end a 1973 340 block but with a steel crank a couple other different modifications I did.
BUT, it was a solid daily driver for years down here in the Tampa Bay Area heat and rain and it was actually fun that wasn't that many years ago either....
742’s were ‘61-‘69 I believe. Which would only cover the C’s on the list above, or maybe some of the B’s or E’s depending on exactly when the cut off was (model year ‘69 vs the actual year, which would cover model year ‘70 too).
But if we’re talking an 8 3/4 rear end that was cut down for a race car that 3rd member could be out of anything. And the brakes could be off of anything for that matter, the 11x2.5’s were a lot more common on the later cars on that list which wouldn’t have had 8 3/4’s at all. A lot of the C-body 8 3/4’s had 11x2’s, at least the couple of C-body 8 3/4’s I pulled from the junk yard did.
