[WANTED] Rear End For '67 Dart (Upgrading 7 1/4)
Are you looking for a 7 1/4, 8 1/4, 8 3/4, or Dana 60?
Limited slip type or open?
Gear ratio?
Rebuilt with new parts / gears?
Fully loaded brakes?
5x4 or 5x41/2 bolt pattern?
Thanks for the response! Here's my replies:
- I'm not looking for a 7 1/4 since I'm upgrading to a stronger rear end, so anything else that's available
- Limited slip preferable but I can do without it for now if it's a good rear end otherwise, especially like a 8 1/4 since I believe I can use a Sure Grip from a Jeep later on
- Ideally? 3.23 or 3.55. I'm building a cruiser.
- Ideally rebuilt but not a huge deal breaker
- I'm fine with drum brakes
- 5 x 4 1/2 preferable
I was initially thinking about a Ford 8.8 but due to time constraints I can't mod one right now, so looking for other options out there.
Thanks!
Howdy,
I'm looking for a complete rear end for a '67 Dart which originally had a 7 1/4.
I'm located in Texas. Thanks!
are you wanting an 8 3/4 or an 8 1/4 which will have big bolt pattern? that will be helpful to know for members that have what you are looking for
