Rear end mounting
72ScampTramp
Scamp Tramp
Fort Dodge Iowa
If I hang the rear and use the perches and bolt them can I move the car that way? I will weld later just not ready yet.
I do not plan to drive this with it just bolted. Just to be able to roll the car out and back in the garage.
I think I would be tempted to at least throw a tack on each end of the perch to keep the rear from rotating. I'm not sure it would, but you never know.
Just set the rear on the perches,use your u-bolts to hold in place(don,t torque them)With no driveshaft or brakes hooked up,you should be fine to turn the car around.:D
ive actually drove em not welded.....just up on a trailer and very easy.u will be fine just rolling it around as long aw u dont try to use the e-brake
