I posted a while back that I thought I was developing too much heat in my rear. It is a 68 Barracuda with a 8.75 sure grip. refresher- This was a new rebuild about 5 years ago. It has sat around since then until I put the car together last year. Of course the guy that rebuilt it really doesn't want to hear about my problems since he did it 5 years ago for someone else.
I have about 700 miles on the rear. It has now developed a leak in the front seal where the yoke is. I got ahold of an infrared temp sensor yesterday. After some driving, the center section was about 100 degrees. it was a hot day here yesterday and I checked my daily driver and that was about 100 degrees also. When I shot the front section where the yoke is, and I assume there's a bearing right there, it was 120 degrees. I had only driven about 8 miles. I think I've determined that is where the heat is comming from. Is there a bearing there? How hard is that to change? Do I need to pull the center section to do it? Anybody got any ideas or experience here?
