rear end swap sticky?
diymirage
HP@idle > hondaHP@redline
michigan
hey guys
i am looking for a stronger rear end for my 71 duster (i know right, who isnt)
could we make a sticky of what different rear ends would be a direct or almost direct bolt on?
would for instance the rear end from a jeep fit ?
i am also looking at a 66 fury station wagon...would that fit?
Or a list of Ford rangers (small ranger) 2 or four wheel drives, what years and what is best for our lite A Bodies and early A Bodies, I have seen some of these threads and try to read threw them but the info on things takes for ever if not imposable with out asking the board
I like this thought diymirage :glasses7:
This seems to be what most sites are using as a guide for rear ends
Width Year Model
56.50 1969-1977 Maverick 8"
57.00 1974-1978 Mustang II 8"
57.25 1957-1959 Ford, Ranchero, Station Wagon
57.25 1965-1966 Mustang
58.00 1966-1977 Bronco
58.00 1964-1965 Falcon
58.00 1977-1981 Granada/Versailles
58.50 1977-1981 Versailles
59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
60.00 1967 Cougar
60.00 1958-1960 Edsel
61.00 1964-1971 Ford Full Size
61.00 1949-1951 Mercury
61.25 1957-1972 Ford F-100 Pickup
61.25 1960-1964 Ford Full Size
61.25 1971-1973 Mustang
61.25 1967-1973 Torino, Ranchero, Fairlane
63.00 1970-1979 Ranchero & Torino
63.00 1972-1979 Ford Full Size & Intermediate
63.50 1967 Fairlane (Coil Springs)
65.25 1973-1986 Ford F-150 Pickup
65.25 1978-1986 Bronco
65.25 1973-1986 Ford Van 3/4 Ton
68.00 1972 Ford Van 3/4 Ton
69.25 1977-1986 Ford E-150 Van
Mopar
Outside
Width Year Model
55.60 1960-1976 7 1/4 A-body
55.60 1973-1976 8 1/4 A-body
55.60 1966-1972 8 3/4 A-body
55.60 All 8 3/4 A-body
56.00 1932-1934 All Mopars
57.40 1963-1972 7 1/4 A-body
58.54 All 8 1/4 F-body
58.54 All 8 1/4 M-body
58.54 All 8 1/4 J-body
59.00 1935-1936 All Mopars
59.14 1966-1970 9 3/4 B-body
59.20 1962-1970 8 3/4 B-body
60.00 1937-1948 All Mopars
60.70 All 8 3/4 E-body
60.70 All 9 3/4 E-body
62.00 All 8 1/4 B-body
62.00 1971-1974 8 3/4 B-body
62.00 All 9 1/4 B-body
63.40 All 8 1/4 C-body
63.40 1971-1974 8 3/4 B-body S.W.
63.40 All 9 1/4 C-body
Mopar
Outside
Width Year Model
Not sure about the non-Mopar stuff, but the Mopar list is completely useless. Junk. Garbage. Outside of what? It's not drum-to-drum. It's not flange-to-flange either. And, I can tell you from personal experience, that A-body 8 3/4's and A-body 7 1/4's are NOT the same width. The 7 1/4" is about an inch narrower drum-drum.
While this is not my list, I have confirmed the lengths of the A-body, 65-67 and 68-70 B, '65-69 C, E body, and even the '65-71 D100 8 3/4" measurements listed here from actual 8 3/4 rear axles in my possession.
These are actual drum-to-drum measurements for 8 3/4" rear axles.
A BODY
'66-'72= 57 1/8"
B BODY
'62-'63= 58 1/2" (And '64 Max Wedge)
'64 = 60 7/8" (Exc.Max Wedge)
'65-'67= 59 1/2"
'68-'70= 60 1/8"
'71-'74= 63"
'71-'73 wagon= 64 3/8"
C BODY
'65-'69= 61.75"
'70-'71= 63.0" (Chrysler & Fury)
'70-'73= 64 3/8" (and '69 wagon)
IMPERIAL
'65-'66= 61 15/16"
'67-'69= 62 5/16"
'70-'71= 59 3/4"
'72-'73= 64 9/16"
E BODY
'70-'74= 61 5/8"
A100
'65-'70= 61 3/4"
D100
'65-'71= 63 15/16"
'72-'74= 64 3/8"
And here are the housing flange-flange measurements
A BODY
'66-'72= 52 5/8"
B BODY
'62-'63= 53 1/4" (And '64 Max Wedge)
'64 = 55 5/8" (Exc. Max Wedge)
'65-'67= 54 1/4"
'68-'70= 54 15/16"
'71-'74= 57 7/8"
'71-'73 wagon= 59 7/16"
C BODY
'65-'69= 56 3/4"
'70-'71= 57 7/8" (Chrysler & Fury)
'70-'74= 59 7/16" (and '69 wagon)
IMPERIAL
'65-'66= 57"
'67-'69= 57 3/8"
'70-'71= 54 3/4"
'72-'73= 59 5/8"
E BODY
'70-'74= 56 31/64"
A100
'65-'70= 56 3/4"
D100
'65-'71= 58 5/16"
'72-'74= 59 7/16"
F BODY
’76-’80= 54.34” (8 1/4 axle!)
As for the Duster, I'm using a '68-70 B body 8 3/4 in mine. The offset on my rear wheels matches the front pretty closely with that set up, but I'm running 275/35/18's up front and 295/35/18's out back. I don't think I'd want to go much wider than that though. Modern offset wheels work well with the 65-67 and 68-70 B rear, but anything longer than that would get tough to find the proper offset/backspace for.
so i guess if we go with this we need to decide how we measure it so we can all be on the same page
memike, the ranger rear ends you mentioned, are those direct bolt ins or do they requirer cutting and welding just like the ford 8.8 we allready have a sticky on?
also, maybe we could put a rough HP capacity on them so we can pick a rear end that fits our build?
The most useful measurement is wheel mounting surface to wheel mounting surface. That allows you to get the backspace figured out for your wheels. On the list I posted above, the "drum-to-drum" measurements are the same as mounting surface to mounting surface. Obviously for rear ends with disks you'd have to call it something different. :D
The only issue with that measurement is that it's not the easiest thing to actually measure.
Two straight edges and a tape is about the best way. Oh, and a second set of hands.
I have a B rear in mine with 10" wheels and 5.5" backspace. Just right.
