P phatty67 Member Joined May 16, 2018 Messages 10 Reaction score 0 Location new hampshire May 23, 2018 #1 where can i get rear end parts for a 67 cuda?
Alaskan_TA Well-Known Member Joined Nov 12, 2004 Messages 6,415 Reaction score 5,289 Location PA May 23, 2018 #2 Check www.doctordiff.com for what you need.
twayne24365 Well-Known Member Joined Jun 18, 2013 Messages 1,552 Reaction score 331 Location Maryland May 23, 2018 #3 X2 on dr.diff!
737jetdr FABO Gold Member FABO Gold Member Joined Jun 15, 2007 Messages 843 Reaction score 257 Location Martinsville, In. May 23, 2018 #4 x3 on Dr diff!
Dana67Dart The parts you don't add don't cause you no trouble FABO Gold Member Joined Jul 16, 2017 Messages 14,883 Reaction score 12,242 Location Northern Colorado May 23, 2018 #5 X4 Dr. Diff but also Ebay, here at FABO and Craigs list, local wrecking yards.
P phatty67 Member Joined May 16, 2018 Messages 10 Reaction score 0 Location new hampshire May 24, 2018 #6 Thank you
P phatty67 Member Joined May 16, 2018 Messages 10 Reaction score 0 Location new hampshire May 25, 2018 #7 ok DrDiff did not have what i need. its a 9 bolt 7 1/4 27 spline im looking for the power lock internal parts. help Last edited: May 26, 2018
leblanc member 2883 Joined Jun 5, 2006 Messages 2,213 Reaction score 377 Location Dieppe, New Brunswick, Can. May 25, 2018 #8 You would have more choices if you had an 8.25. It handles more power too.
fishy68 Tyr Fryr's Inc. Joined Jan 11, 2005 Messages 16,584 Reaction score 1,264 Location Central, IL (Hooterville) May 26, 2018 #9 Have you tried RockAuto? I see parts listed for the 8-3/4. Haven't looked for anything for a 7-1/4
P phatty67 Member Joined May 16, 2018 Messages 10 Reaction score 0 Location new hampshire May 26, 2018 #10 unfortunately its not my car. i would pull this rear end and put a different one in. i will check rock auto
P phatty67 Member Joined May 16, 2018 Messages 10 Reaction score 0 Location new hampshire May 26, 2018 #11 does anyone know if they make a good posi traction replacement carrier for this rear end ?
D DoctorDiff Well-Known Member Joined Sep 30, 2012 Messages 341 Reaction score 365 Location Polson, MT May 26, 2018 #12 I don't know of a source for ANY 7.25" sure-grips.
leblanc member 2883 Joined Jun 5, 2006 Messages 2,213 Reaction score 377 Location Dieppe, New Brunswick, Can. May 28, 2018 #13 Some Dodge four cylinder 1/4 ton trucks used the 7 1/4 maybe they had a posi too??
