Vali68
I have a slant 6 225 that I am putting back together. I applied the gaskets for mounting the oil pan to the block. Looking at the rear rubber seal that covers over the rear seal housing, I can't tell if this is th eway it is supposed to look when completed or not. is this right or did I put something on backwards?
Also, I see 2 separate specs for torquing down the oil pan bolts. one says to 100inch and another says 200inch. Which is correct?
I am using the rubber seals for the front and the rear of the pan and cork for the sides.
