Rear shackle help
mopowers
West Sacramento, CA
When you guys relocated your springs, what was the ID on the tube you welded in the frame for the rear leaf spring bushing? Also, can you use stock shackles when you relocate the springs?
The inside dimensions is .85 of an inch, or just shy of 7/8 's.
The rear shackles that come in the kit look like stock replacments, in looks and measurements.
