Rear shocks with leafs moved in.
rick4106
louisiana
Just put my cal trac -1 setup on my sons car with leafs moved in. Calavert shocks are too long. What is everyone using
They have shocks for lowered applications IIRC.
Too short is MUCH worse than too long!
Viking da on mine, standard length. I also ran the same Rancho's that I ran before the springs were relocated.
When I ordered Rancho 9000's for my car i know they were available in two different lengths. I took the longer ones as my springs are not relocated.
Too long as in they are bottomed out or close to it at ride height?
I just used the stock length ones on mine.
Go to Summits web sight and look for Rancho 9000 shocks. They have several pages of different lengths. That is what I done. Measure what you need and you will find it there.
what are your measurements on the car and on the new shocks, compressed and extended? I run Trailmaster rear shocks
I looked up Rancho RS999113 on Summit and they are listed as 13.28 inches compressed and 20.03 inches extended.
