This is for a '64 Dart 270.
Does anyone know where to get these rear upper shock studs? When I removed these shocks to put on new ones, both sides had these nuts froze on. I cannot remove these from either shock. I've tried lube and heat to no avail.
Napa did not have them. The only studs they had were about two inches shorter.
The ones I've seen online don't look the same so I don't know if they work? This one from Summit maybe? Though it doesn't list the overall length.
Classic Performance Rear Shock Mounting Studs CPSMS
Any leads would be awesome....Thank you!
