Rear wheel travel. New suspension set up
mike240
AZ
When setting ride height, how much vertical travel should I allow for, for a street fun car. Car is already stripped so cannot just measure oem axle to snubber.
Putting in a 9” with QA1 coil over rear suspension. Want it low but safe and tires not hitting my tubs. 2 inches?
What does QA1 say? And what’s the spring rate on those coil overs?
Factory front travel is about 5”-5.5” from bump stop to bump stop, about 2.5” on compression. The rear was more than that but I forget the exact spec.
2” in the back would be the absolute minimum for me, you just won’t have enough compliance to keep the wheels planted on the street. Whether or not that’ll be enough room for the wheels/tubs will depend on the rest of your set up.
