install the rubber seal in the channel make sure seal is unlocked (not tucked in) install glass on seal lip easiest to start on one side and work your way around. lock/zip the seal closed, install reveal molding. go for a drive..
if you have sealer it goes between the glass and the seal not the seal and the body, but could if you had too.
