Rear window trim clip location??
70DartMike
Too many projects
Vancouver Island, Canada
Does anyone have a picture of the rear window trim clip location on a 68 - 76 Dart? My body guy mistakenly welded some of the holes closed thinking they were rust pin holes. I need the bottom, and both side valleys. Thanks.
Dang, I just had my glass put back in a week ago. I don't know that the position is really that critical- just use the same number and spreading them out. If you need you can buy new ones too.
Bruce, the window guys came back, pulled the rear window, and removed the new clips I had bought for an A body, and used Ford clips from a newer pickup I believe. They're the same size, but just a bit looser of a fit for the trim which makes it much easier to install. It's been over a year now and the trim is perfectly snug.
thx mike --my clips will work but I was wondering how you figured out the clip location after they were welded up by mistake
bruce
