As I do, the rear that I currently have in mine is supposedly from a late 50's something or other (unsure, but didn't care because it was ever so slightly narrower than the 65 b body rear I had in it. It measures 41 3/4 flange to flange (housing flange) I also run a set of steel wheels I had made 10 years ago by Stockton Wheel (way overpriced, any good wheel shop should be able to widen a stock set for less or you should be able to find brand new aftermarket wheels with the proper offset/backspacing, you should measure for the proper fit, trying wheels and tires can get expensive fast.) My wheels are 8 inch wide with 5.5 inch back spacing and my 73 just clears, with 245/60 15's, the outer wheel well lip and has about 3/4 inch clearance to the leaf springs, I have had 255/60 15's on it and they clear to but they will rub the very side of the tire high in the wheel well if I have a full car (wife and kids and me). Each car is different, measure, measure, measure, then buy.
