PRH
Maybe you are!!
I guess they do sell bare heads. Thats about what I paid for my assembled heads last summer.
It sure is. If I was to run a open chamber head, can I still run the pistons at zero deck heightJust looked up my receipt.. bought an assembled set of SBM 171's 04/21/21 and the price was $1437. Same set today is $1692. Inflation hitting everything.
How much have you spent on the cylinder heads that you are running now?I'd have to be dealing a lot of "something" to afford those!
I think that I'll still run them at zero deck height as that not only helps the compression ratio but flame travel tooI had similar questions (not zero deck) and have received varying responses. I will not know for sure until I get the new heads mocked up on the block.
On my end, part of the initial cost of the entire car, lol! They're stock 675 318 head with a .010 cut and a more performance oriented valve job than stock. But I'm starting on a set of iron heads that quoted for around an $800 to $900 outlay, but we're going to have to see what inflation is going to do for that. That's not including my time for what little home port work I plan on doing. There's quite a bit of machine work and parts for that, though.How much have you spent on the cylinder heads that you are running now?
