I've got an A body 8 3/4 in my garage. It was a pull out from a junkyard from a 1970 Dart and has an open 489 case with 2.76 gears in it. I'd like to do a complete overhaul to it and rebuild it before I throw it in my 1968 Dart. This includes taking it all apart, powder coating the case, installing new bearings, carrier, and bbp axles from Dr. Diff as well as installing new lines and a disc brake kit (Dr. Diff again). I know it's going to cost an arm and a leg, but I was wondering how much can get done at my garage at home. Is this a difficult task? Unfortunately, I don't have a press at home for the bearings. Are there any other tools needed?
I do have the 1969 service manual, but sometimes I have trouble following that and tend to do better when taken instruction by people.
I'm also unsure if I should get 3.55 gears or 3.91 gears. I do drive the car on the freeway on occasion, but I would like to install an overdrive transmission of some sort to it in the future (may be a couple years before I get to that).
