gdizzle
So just got my rebuild kit from Mikes #K458. This is for my 225 slant 6 1966 dart. This is the 1920 Holley. When I opened it up there is no baffle. Though I clearly see slots to hold a baffle in the casing. Is that ok? The float looks original, and weighs about 9 grams. There is also a ball bearing he included, but the check valve in mine does not appear to be removable nor does its ball bearing. In fact I do not understand how the check valve is supposed to work if it cant be removed? There are also 2 small ball bearings actuated by a plastic piece. These dont appear to be replaceable either.
Anyone have ideas?
Anyone have ideas?
