[SOLD] Rebuilt 360 engine for sale
Hellrats
Just another dumbass
N.E. Ohio
Like the title says... Built this engine about a year ago. Was going to go into a project car but things have changed. It has not been started yet but the oiling system has been primed with break in oil. I'm northeast Ohio and really DO NOT want to ship it at this time, but I will deliver within reason as I do work full time. All you need is a carburetor. Is has one in the pictures but it does not go with the engine. $2000 dollars and it's yours.
Just the cross over and plugs behind the camshaft plate and a hi volume oil pump. The block was going to be a back up engine for a race car that never happened. Then built as a street car engine... that never happened.
Factory balance. The Speed Pro pistons are the same weight as the factory ones. Just a bit taller for more compression. Had the machine shop check all that.
