MidnightSwinger
These have a few thousand miles after being rebuilt. Stock ports and valve size, Mopar Performance orange springs.
The car I got them from was my buddies show car, only had a few thousand miles on a total rebuild, with a lot of idling. There’s a decent amount of soot in the chambers that will clean right off. I’m sure you can just run them as is, but I would clean them up personally.
The rearmost intake bolt hole on the driver side head will need a helicoil or thread repair. Other than that these will bolt on and run. Comes with the head bolts and rockers if you want them.
$150 Located in Woodland CA 95695.
