Recommend a tranny shop in Phoenix?
Jeff Koch
Phoenix, AZ
Hey everyone:
My '64 Dodge Dart GT's pushbutton 904 currently can't hold its fluid, and will be backing a mild (300hp) 360 in fairly short order. Does anyone know of a local, honest shop that won't break my bank that can poke around and see what's what? I don't need a hi-po buildup with shift kit and the like, just enough that I won't snap something if I decide to stomp on it now and again.
Many thanks in advance ...
jk
Not in Phoenix, my friend is out in AJ. Does outstanding work. http://www.buytransmission.net/
Doug is about as honest as you can get. He can build you a full bore race unit, or just a nice simple street unit. I drive all the way from Spokane Washington to have him do all my trans stuff.....
I wish I knew of a decent shop Jeff (anywhere)
If you have a place to do it and some tools, I might be convinced to come down there and help you with it on any given Sunday. (more likely a Saturday morning)
Even if you don't want a "race" trans, you will want to make some minor mods to it.
Like,
Open up the 1-2 and the 2-3 oil orifices in the separator plate.
Block the accumulator.
Change the mainline pressure valve adjustment.
Locktite the front seal in place.
Take a little weight off the governor valve so it shifts a little later.
The problem is that in order to actually make it stronger you would need a few hard parts. (steel planetary set, 5 disc forward drum, band lever, kevlar band).
The 904's are pretty tough as they are though.
If nothing else, get the stage 2 shift kit for it.
This will give it more pressure to hold the clutchpacks and bands so they dont slip (300hp) and make it shift a ton better.
The kit will also make all the recommended changes I wrote above as part of the kit instructions.
A shift kit and a soft parts rebuild kit would be a really good call.
Soft parts rebuild would be clutch friction discs, band, the rubber lip seals inside the drums and all the outer seals. (gaskets and stuff are included)
I can do the whole thing in about 2 hrs. (If it's already out)
An inclosed area with lighting and a bench would be a must.
Hey everyone:
jk
There is a Mopar guy who builds transmissions in Peoria around 83rd and Deer Valley. If you're interested send me a PM and I'll dig up his card.
I'm grateful for the offer ... but I have no bench, no lighting, and no expertise to get the thing out of the car. Other than that ...
jk
jk
4 months later and going into summer, you'd have a hard time just getting me to come down there at all now. :D
