magnumdust
What would you guys suggest for a great street/strip cam on a 5.9 magnum(w/ rhs heads)
I say custom grind. Since its hydraulic roller its expensive anyway, and with a Magnum you can have it ground on an LA core, so you get the snout for the mechanical fuel pump.
well that's not really an issue. I bought the snout adapter from mancini.
who does custom grinds?
Roller of course.....Really need more info to make an educated guess,
Intake manifold? single or dual plane advertised power sweet spot
exhaust headers/manifolds?
carb cfm, vac or mechanical secondaries?
rear end gears?
converter stall speed?
tire size?
distributor stock or aftermarket?
heads 1.92 or 2.02 bowl work or ported?
compression ratio?
power adder nitrous/turbo/supercharger?
good place to start to get a general idea go to compcams.com and download camquest6
oh btw edit, doubt it makes a difference, but:
I've decided to go with the EQ iron ram heads. Same 1.92 intake valves.
Call Brian at IMM.
He can get you a custom cut comp for same or less than most shelf grinds.
Don't sweat the nitrous if you run it with using some common sense
Ok I found it, if you have plenty to spend go with crackedbacks advice, If youre on a budget and want quality parts at a really good price read on.
The guys name is kenneth caudillo
his email: xezconditionx@yahoo.com
the mopar master grind list is at:
http://myspace.com/utilitycomponents
looks like the HR 279 280 or 286 might be good for you if you get that converter you were talking about. I went with the HR 276 because the stock magnum heads will have retainer to valve guide clearance problems at about .530 lift. Its lift is .512 and when I had it assembled and in the motor I had less than .020 clearance. Incidentally, I degreed the cam after I installed it and it was exactly as advertised on lift and only 1/2 a degree of on the centerline but I attrributed that to the timing gear quality control.
I bought one from him and turned two other FABO members on to him who were also please with their cams and especially the price 120 buck delivered to your door. of course rollers lifters are entirely reusable so your probably looking at a set of valve springs to go with the cam unless the heads you are getting are already assembled, the absolute best deal I could find for magnum springs that will fit the without machining are the 1102 from Hughes engines for 65 bucks, they will support a camshaft lift up to .550 lift
You're right to predicate your opinion on my low budget. Afterall, my original intention was to throw this engine together as is, but then i got it to my friends shop and he insisted on a pulling the heads for new gaskets etc etc. So if i'm gonna go this far, might as well go all the way.
Will i need new pushrods?
The heads i'm getting are the iron rams assembled from hughes:
"assembled with new valves (1.920" stock style alloy steel intakes and 1.620" one piece, non polished exhaust). The heads come complete with Viton valve stem seals and our 1110 spring kit. "
Would the HR279 280, or 286 work well with the stock converter? At least for the time being. Its likely that i won't be getting an A500 until at least tax return season.
Another thing i should mention, part of this thread is that i know nothing about cams.
Do yourself a big favor and get the heads machined so they can take a better spring down the road.
There's nothing that goes on these heads in stock form that's better than the 1110 springs, and my car could definitely use an upgrade already. I'm thinking about buying the 2.02 head just so I can get better springs without taking the heads off and having downtime.
If you are definitely going to get a looser converter then you have more choices. From what you described as your parts if you get a converter that stalls from say 1800-2200 you could run the 268, 270, 276, or even the 280. All 4 of them call for a stall between 1800 and 2200 and at least 3.42 rear axle ratio which you already have with 3.55's. The compression ratio on your stock 5.9 is factory advertised at 9.1 to 1(depending on the year). The problem with that however is that what the factory advertises the CR to be and in actuality is probably a whole different story. I wouldn't be surprised if your pistons were .050 down in the hole and you actual compression is actually 8 to 1 or maybe even less. I have found best success when you have unknowns or "unsures" or borderline specs necessary to run a particular cam that using a little less camshaft than what "desktop dynos" call for as a maximum cam is a good bet.. . If it were mine I would probably run the 270 or 276 if you get a converter that will flash to 2000. Of course the higher you stall will lend itself to the 279 or 286. If your definitely getting a higher stall converter then you can always put more cam in there till you put the converter in there. But then youre back to the limiting factor with the CR, I wouldn't bank on youre having a true 9.1 to 1, so that would put you down to the 270-280 range. But you can measure everything when you pull the heads and mill the heads to achieve the compression ratio you want. I don't know what the combustion chamber volume is on the heads you are getting but i'm sure that you can make a situation to raise it . But, now were spending even more money, .All these cams are running an LSA of 112 which will definitely take some of the lopiness out of the camshaft. However not all is lost with that. I did a bunch of research on what cam to run with nitrous. It seemed that the more I read the most common specification that was common to most advertised "nitrous cams" was a lobe seperation angle of 112-114 degrees. So your cam might not have that heavy lope and sound very "cammy" but you will make more power on the 112 LSA than one with say a 106-108 LSA. If you currently have a 904 and want to get out of this absolutely cheap until you acquire and build an A500, you can get a slant 6 converter (72-80 had 27 spline input shaft and 27 spline slant 6 904 converters are plentiful and cheap) and install it behind your V8 904 and achieve an 1800 to 2000 stall speed. There have been so many free slant 6 engines and slant 6 trannies advertised here that you can probably get someone to give you one if you pay shipping. Hell, I have one I would give you but it is out of my 70 and has different number of input splines. Do not need new pushrods or lifters.
will the slant 6 converter hold up to the abuse?
Honestly, its not an issue to have that "cammy sound". V8s that start to sound too lopey are not for me.
So my cam came today. I shot an email to the person that dustoff440 suggested. He never replied and so i gave a call to brian at IMM and ordered from him
Specs are: intake exhaust
adv. duration: 276 282
dur @ .50: 224 230
valve lift: .513 .513
110 lobe separation
It came 1 business day earlier than i expected![]()
