redrilling rear drums?
1973DartSport
Maine
anyone ever have any luck redrilling bbp rear drums to fit sbp rear axles on an 8 3/4? thanks.
The drum wont be able to center itself on the axle hub that way, the center hole in the drum is too big.
I drilled sbp to bbp. It worked just fine
sbp to bbp.
If you want sbp rear drums, I have a set. Just upgraded my 67 Dart with 8 3/4" rear end
from sbp to lbp - also have the sbp axles with the factory bearings.
