Refine web searches
Bodyperson
Pedal to the metal
NW MONTANA
This suggestion is not so much a "For A Bodies Only" specific suggestion but is helpful in all
Google searches. For starters, you could just Google "refine web searches" and that will give you a host of symbols or words to make your search results more precise in the Google search engine.
Mind you, this only works in a Google search engine.
My favorite command is the word "site". If you type the word site along with the : symbol along with your search criteria, it will open several different FABO discussions about your inquiry.
EXAMPLE: site:forabodiesonly.com header size . You have to make sure there are no spaces when you type... site:forabodiesonly.com There are other commands that could be added to this to refine your search even further. I hope I have conveyed the idea.
EDIT: I forgot the dot com part originally
