[FOR SALE] Refresh 318 Engine Package
540slant6
Mopar SB Ripper
Berryville, VA
Selling a refreshed 70's 318 with new Sealed Power rod and main bearings with Hastings rings. All stock spec replacement, engine was pulled from a running 78 D100. New cam bearings as well. Did a ball hone on the cylinders and everything looks good.
Package includes the following:
Refresh 318 short block
Used Crane cam .504/.504
Double roller timing chain
273 angle milled and ported 273 heads
Freeze plugs in package
Hydraulic stock valve gear
Head, oil pan, intake gaskets
Electronic small block ignition kit
Short block assembled and everything else is loose. Great father/son or father/daughter upgrade for a slant six Mopar. I know it's always a gamble buying refreshed blocks so I'll do a full refund if there's any issues.
I was going to put this in my 72 D100 but came across a 340. Pick up only and located in Lovettsville, VA 20180. I will entertain trades for HP small block parts.
Asking $700.00 OBO. Thanks for looking and God bless.
Nick
Ng g
Pistons are about. 073 in the hole, not too bad for compression with smaller cc heads and a bunch of timing.
