regulator
moparwedden
trenton,ontario,canada
My Regulator Bit The Big One, Till I Get A New One On Tuesday Can I Run My Electric Fuel Pump Without One Till Then. Just A Short Run Around Town.
depends, what pressure is the pump running w/o the regulator? and im guess ing ur running a carb, so u want 5-8psi roughly. if the pump is putting out more u'll blow the seals, and the needle and seat wont regulate fuel level.
It all depends on how much fuel pressure the pump puts out. If its a pump that puts out 7 psi and no more, I would say yes.
