Sure....but this question is loaded like a Chinese Import OceanLiner.
Heat drives the power, but is also the enemy.
Keep the boost sane enough for no detonation on whatever fuel you want to run, and you'll never have any problems but traction...and where to get another set of "xxxxxxxx Tires".
Ideally, you need a 750 Blowthrough Carb, 74mm+ turbocharger Compressor Inducer, and a 70ish mm Turbine Exducer with an A/R choke of .86 OR 1.04, 50mm external wastegate, 50mm bypass valve and full 3.5" exhaust pipe from turbo to exit....and 600+ pumpgas streetable, reliable hp is a throttle tip-in away...with 8.5:1 CR and 14 psi.
But let me be the first to tell you...there are a ton of Real World Variables (budget) that will affect each different setup.
