for the battery cables most of us use welding cable ..size one ought ( 1 / 0 ) solder the ends.... i use a # 4 guage welding wire for the positive charging wire, the welding cables will carry full voltage the lenght of your car without loosing any power. use a relay for you fuel pump (mounted mine in trunk) so you dont need a big heavy wire the length of the car for it. mount fuel pump near to the fuel cell, fuel cell needs a deflector or shield on the bottom that is exposed . ( the part that extends down through the trunk floor )i used a piece of light gauge alum for this .... summit and jejs both offer a through the firewall connector to get electric power into the car , you also need a battery box, battery cut off switch mounted on the rear of the car. i put mine where the license plate should be. try to run the battery cables away from the fuel lines and under the car... for a fuse block i picked up one at a napa dealer for about 10 $ ..uses the common spade fuses and has room for 10 circuits.....oh yea and a rear firewall ( goes where the upper part of the back seat was)......that should keep you busy for a little while......good luck......Ron
this is what you need to be track legal , less if its a street only car
