Remote mirror controls
Beckner
Member
Arizona
Need some help on what goes on the inside of the door to hold the remote mirror control in place before the Basel nut screw on
Thanks
I think someone posted a source for that part in a thread here. Some later models have a tang in the hole in the sheet metal to keep the controller from rotating. Those only got a thin hex nut on the controller.
I wouldn't know how to find it or even Google the part since I don't know what its called. Good luck
In
thanks. I have a square steel washer but that doesn’t seem to work
The square flat washer does not hold the control. Also when a screw in the Bazel nut, it is not tight against the door panel. Almost like there should be a jam nut or something on the inside.
Just doesn’t make sense
If you'll google images, you might find what you are missing. You never stated what model you have so we are limited in what we can offer. Some mirror controllers and other switches were mounted in metal while others were mounted in plastic. I took long cables from a right mirror in 87 Garnd Fury at the parts yard. I found the same square locator where that controller was mounted in plastic of dash bezel but if they had found they could cut the hole in metal little differently you can bet they would have saved a dime.
dodge 69 remote mirror controller bezel - Bing
Does that look like it would fix you up?
Sorry, 70 Duster. It had the driver remote mirror. I ordered and am trying to install a factory remote mirror. The issue I have is the control knob in the door panel.
I ordered a retainer washer. That doesn’t seem to hold the control knob in the notched hole in the door. Not sure what I’m missing
Thanks
Is this what you ordered?
A-Body - Mirrors - Mirror Hardware - 521 Restorations
I didn't look really close at these reproduction clips
but they are missing a tab at the top.
