Remove Door Mouldings from a 72 Dodge Dart
Swissoldtimers
New Member
Switzerland
I didn't find a solution on this forum after a quick check.
I have a swiss built Dodge Dart 4 Door 318 ci. Now I wan't to remove the trim from the door.
Before I remove the whole inner door panel, I'd rather ask for advice here. Are the trim strips on this model screwed or fixed with clips (at the very front and very rear they are screwed. But in between)?
Thanks for your support
Mine were just glued on but I bought a door that had holes drilled with plastic clips holding the trim to the door through the holes. If yours have holes drilled through at the door edges, I’d say for sure, your trim is clip mounted.
Generally if they have screws at the ends then they probably have hat pins welded on and nylon clips. Remove the screws and then use the blade to pop them off of the clips.
