Remove Tail Light Panel to Replace Trunk Floor?
Piston Speed
Member
Austin, Texas
Howdy,
Got a '72 Demon that needs a trunk floor and both extensions. I see that AMD sells a one-piece, aftermarket floor.
Without cutting the AMD floor, is the only way to replace the trunk floor is by removing the tail light panel? The car doesn't need quarters or anything.
Thanks.
You can install the AMD floorpan in your car, without removing the taillight panel, but I personally like to remove the original tail panel, only for the ease of not having to work over top of it. Plus you have to drill all of the spot welds at the lower back bottom area (90 degree edge ) of original trunk floor. I can answer any other questions you may have. Dodge33
