Removing gas tank filler tube
pauls340
17 miles N of Detroit
Is it possible to remove the filler tube without dropping the tank? I need to mount it thru the fender so the gas cap fits correctly. Anyone know the steps involved? Thanks
Yes. Remove the screws holding it to the fender. Disconnect/detach vent tube from filler tube. Slide trunk pan seal up filler tube carefully. Put a little lube on filler pipe just before tank grommet and slide pipe into tank. Turn pipe to the side and it should just pull out. Check the tank grommet carefully for tears and replace if damaged (trust me on this one).
I think you are going to have to drop the tank. Does it have gas in it?
I would remove any screws holding the tube to the fender, remove the screws and slide the trunk floor seal up the tube a ways (you may have to lube it with some WD-40) and then drop the tank.
C
MoparLvr-Where would you purchase that gromment if it is cracked?
I need one...
I got one from RPM here in Canada but Year One carries them and I believe they are still available from Dodge.
Several ebay stores have them also. If you need more info I will check my saved sellers list.
