Removing Heater Box
https://m.summitracing.com/parts/VTA-50616-VUZ/
Not available through summit. I could sell you mine I guess. I'm looking to go back to the stock non a/c box.
I did, 68 fastback form S car. mounted the aftermarket hotrod heater up under the center of the dash. you`ll have make brackets to hold it. the heater hoses took some coniving , due to the original hose holes having my fuel inj. harness routed thru them.
