Repair frayed throttle cable?
1MeanA
Edmonton
My original throttle cable is frayed. Has anybody replaced the cable? I would think securing the end stops would be the challenge.
ps I did buy an expensive repro
a good bicycle shop or custom motorcycle shop could probably set you up with a custom cable.
once they're frayed like that, there's really no coming back and replacement is generally the best option-- generally because that means the inner liner is damaged as well.
I thought I would check before I tossed it. I am cussing trying to sort out my new cable/throttle bracket/Eddy 1906 carb linkage and about to go Lokar anyway.
that should pretty much be a slam dunk. you have the mopar throttle arm and stud that goes onto the stock eddy stuff?
or are you talking about 2bbl ==> 4bbl swap and that part of the linkage/cable hold down?
I've never been happy with the throttle cable set-up. Its an Edelbrock 1906 with the Mopar 1481 adaptor on top of an RPM intake. I have a Mancini (I think) cable bracket and it doesn't line up with the 1481 adaptor. The bracket puts the cable too far inboard and it seems too far forward. I would have been better off not using the 1481 adaptor. On top of that the cable seems too long as it sticks out of the pedal an inch or so. I just installed a new repro 340 cable and the bend is so hard that it won't go through the firewall straight. I spent a few hundred on the bracket and cable and am nearly done with it. I've used Lokar cables successfully before but I was going for a factory stock look this time...maybe not.
I saw someone fix a cable like that by wrapping it with a zip tie then pulling the zip tie over the frayed part while also twisting it.
Any good motorcycle shop should have the ferrules that can be sweedged onto the inner cable to shorten it.
Maybe adapt the bracket rearward somehow?
A cruise adapter bracket worked for me. Likely too high for yours....
I might buy a wire rope stop sleeve and crimper and see if I can make it work. The other option is to buy a universal throttle cable kit and use the parts for the carb end. I believe the stop is a set screw in the sleeve.
Bend it outward, and not just grab and bend
Put something between the bracket and value cover, or take it off, to give it a nice double curve or similar.
Bend the top to make it level again.
Drill extra holes to move the top part back farther.
Basically what I did when I had that setup.
If i take the adaptor off it should line up… tba
