Replacement air cleaner
urrlord
New Member
central ga usa
My 66 Valiant has a Carter BBS that is missing the bail. So I don't have a way to secure an air cleaner to the carburetor. Anybody have a bail for sale? Or what are people using as an air cleaner assembly that have the same problem as me. I thought maybe a clamp on VW type, but all I find are for a 2 inch inlet. BBS are roughly 2.5 inches. So those seem to be out of consideration.
Any ideas people?
How about a wanted ad and go from there.
That’s how you find out.
Syleng1
Go ask on slantsix.org and someone will have one for you. Make sure to specify whether you have the "small 'n tall" air cleaner (a little under 9" diameter) or the "large 'n' flat" type (a little over 11" diameter), because each takes its own type of bail.
