Replacement Plastic Float A-Body Fuel Sender
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
Doing some tweaking on my fuel sender, 67 Dart.
Discovered my 2 year old plastic float had a little fuel inside.
I would have preferred to have a copper one but you got to deal with what you have some times.
I ordered a replacement float from O'Riley's auto parts, not listed as compatible on their website but it is.
Omix-ADA Fuel Level Float
Part #17729.01
The OD is the same.
The length is a tad shorter then my old one and there is no middle Indent
But it works and will do.
